8800gtx power cables
20 May 2009
York
Hi All
I have just put my PC bacl together, but failed to notice which ay round the power cables go, there is a blue one and an orange one.
Which goes where :confused:
I'm a little confused by your question but if both of these cables are 6-pin molex cables used as PCI-e connectors then they should both do much the same thing. In this case - they can go which-ever way round looks the prettiest.
I'm guessing, however, that they're not. Do you have any more details?
they are both 6 pin connectors, only difference is the colour, and one of them has a 2 pin coming from it, which i dont remember it being used before
theyre the cables coming from the PSU straight into the side of the GFX facing out of the case.
Ahh - right. I think the one with 2 pins comming from it isn't a 6-pin connector, I think it's a mobo power connector. I think you want the (pure) 6-pin and an adapter for 2 4-pin molex into 1 6-pin.
Pictures would really help. Also - which PSU is this?
That cable is to plug into a molex camble from your psu then into your graphics card. Its an adapter
no, before i took everything out, both cables went directly into the gfx card, just dont remember which went in which side. Both will fit in each, but i dont know if it matters which goes where
i see, providing the card has 2 cables plugged into it from the psu it doesnt matter which one goes in which socket on the card
cheers guys
Well the good news is this is now being posted from my PC
The bad news is the Pc is making a noise. seems to be coming from around the PSU/Sound card area
It's odd, everything seems to work ok though.
Ill make a post in the relevant section :(
