8Packs own LAN MATX Gaming rig. Project 8lite Tier!!
A little protip for you,when masking stepped surfaces,like dem rams,use a vinyl tape as it will hug the contours much better than normal striping tape.
You can also try a pencil eraser to remove the overspray.
Shame really,you could have sent them to me for a paint job...maybe next time neh?
I like it tho,very clean and simple. An odd choice of sleeve colour tho,would have thought a black or dark blue would have been more fitting?
Yeah the finish isn't great, but for sake of offering equal pro tips, drain your pride and joy before Fed-Ex'ing it :p
I like that look actually. Each to there own.
Perhaps u wanna send your hardware to me for Overclocking? Just a thought :-)
Except ASUS shipped it back to me,not the other way around....
Thanks for your negligible input,im sure Ian is more than capable of sarcastic comments on his own tho.
Im not knocking you,just a friendly tip for next time fella. I would like to think you would have taken it in the spirit in which it was posted.
If you like the gradient look,you can reverse mask it by rolling the masking paper over and spraying,the raised 'loop' will give a great graduation to the spray.
If I had a sample worth OCing,you are more than welcome at the next i series,I can see no reason not to trust your advice on that subject.
