8TB+ HDD Questions (a much better title)
23 Oct 2020
Good evening because in my possession at the moment I have a hard drive of 4 terabyte, and I have filled it, I am thinking of buying 2 hard drives as a couple ... of these 6 models. discs./
Which should I prefer from these 6? the, most ideal and best preferred?
https://www.overclockers.co.uk/wd-8...ernal-cctv-hard-drive-wd80purx-hd-536-wd.html
https://www.overclockers.co.uk/wd-8...ternal-nas-hard-drive-wd80efax-hd-55f-wd.html
https://www.overclockers.co.uk/wd-u...ise-hard-drive-hus728t8tale6l4-hd-55p-wd.html
https://www.overclockers.co.uk/wd-g...tacenter-hard-drive-wd8004fryz-hd-56f-wd.html
https://www.overclockers.co.uk/seag...nternal-hard-drive-st8000vn004-hd-3cd-se.html
in terms of reliability are they worth it? and build quality?
just in my work and at home I have a large volume of data from files. including documents, word ,,, excel ,, powepoint,, music files, movies, series, etc.
1/. I can't read Squiggle and have no idea what half those words say.
2/. Those are links to retail sites that are not OCUK, which is not permitted here.
I suspect those are just two of the many reasons why no-one else has helped.
A cloud storage firm in the USA writes a quarterly blog about their hard drive failure rates & have done for a fair while now. I think that would give you some idea. Just be aware if a hard drive fails under warranty that there's a good chance you'll get a refurbished model as a replacement.
Rule of thumb for any data you regard as sentimental or important for work, either keep an offline backup or store it in a cloud/backup service. I usually do the former with old hard drives I no longer have in regular use.
General storage?
Just use Western Digital Greens, or Seagate Barracudas.
yes i will use it for general storage such as including documents, word ,,, excel ,, powepoint,, music files, movies, series, etc.
so from all these 5 hardisks which is most suitable???
did you see the fotos from the 5 hardisks??
