- 16 Apr 2022
- Birmingham
I will not use more than I USB port so a multi port device is needed. My PC is an enormous hassle to get out from under the table because I have to climb under the desk, reach around a large column, disconnect all the wires and then get out from under the table before I can pull it out. Then repeat that in reverse after putting it back. It's a similar process to access the rear connections to plug anything in except for not removing all the cables. That is just too big a hassle which is why I will not do it for a USB joystick adapter. It's just not an option for me. A hub would most likely increase the latency.
I have sent a message to Retro Lemon about the one which I thought was German, the domain shown on eBay is .de but I believe that it is actually Polish. I have asked a couple of questions. I did already send a message to the one on eBay some time back which has a fixed USB cable and he told me that the fixed cable was to reduce latency which I do not believe because I believe that it is just to cut costs IMO. That is a major issue for me because I avoid products with fixed cables at all costs. The latency on that one might be very low but that fixed cable is just too high a price.
