A day after I bought the 805 last week, OcUK put the 930 on special, so I couldn't resist getting one.....hope there's a market for unused 805s on Ebay
Now I'm back on water, I've quite easily got my 930 running at 3.99GHz (266 x 15) 1.3875 vcore with DDR2 800 running stock on my P5WD2 Premium. CPU temps are about 36 at idle (less than mob) and 51 max at load (both cores) using an old Hydrocool 200, so I still have room to go further. Chipset temps run from 36 to 41, seem more dependant on ambient changes than loading
I am a little dissapointed at benchmark results....not as great an improvement as I expected. Presumably 3DMark03 (12900) is limited by my X1800 XT graphics, but I only get a 2 second improvement over stock settings for Super pi (down to 31s) ?? When I run the 32M calculation it finishes the first loop in 21s rather than the 27s of the stock setup.
Once I get a screen capture program downloaded (any suggestions?) I'll put up some screen shots.
So far it seems rock solid in Prime95 (did 14 hours yesterday, doing similar today on other core), but I'm I'm having problems going beyond 270 Hz so I will need to increase vcore...
....what would be the safest max voltage to use/try?
