With two low RPM fans the IFX-14 is just ahead of the Ultra-120, High RPM fans (1200+) the Ultra-120 is a better cooler.. if you are looking for a silent system probably the IFX-14 is you best bet.. if you are looking for mid to high range performance then the Ultra-120...
Both are better than the TT, which although I havent had general opinion is that it is pretty loud at full tilt... better to get one of the others and put 1/2 nice 120mm on
