9450 air cooling
Wait, if you buy the Tuniq Tower, you have to buy a seperate 120mm fan aswell? I assumed it came with one. Guess not. =\
Edit: Oh sorry I read you post wrong, that only applies to the Thermalright Ultra-120 Extreme.
Yeah the TT comes with a fan.
And I haven't a clue how the IFX-14 performs tbh.
Depends on the fan in regards to the IFX-14
With two low RPM fans the IFX-14 is just ahead of the Ultra-120, High RPM fans (1200+) the Ultra-120 is a better cooler.. if you are looking for a silent system probably the IFX-14 is you best bet.. if you are looking for mid to high range performance then the Ultra-120...
Both are better than the TT, which although I havent had general opinion is that it is pretty loud at full tilt... better to get one of the others and put 1/2 nice 120mm on
