9600KF won't clock down??
22 May 2010
Minibotpc
So today finally upgraded to a 9600KF, build went fine and no issues. However i've noticed that it won't clock down below 4.3, it will hover around 4.4.-4.5 and sometimes 4.6 at idle. Everything is at stock except for memory which i've enabled XMP profile.
I've enabled all C states in bios - not sure if they all need to be on though?
enabled intel speed shift technology
Disabled multi core enhancement
Windows 10 processor state min 5% and max 100%
Am i missing anything?
Thanks
Okay so i set the power plan to balanced and that worked, however when i set it to high performance and set the different processor states it won't down clock. Is there a way around this?
You can change the Attributes DWORD for the "Processor Energy Performance Preference Policy" to 2 in the registry, the setting will then be visible under the "Processor Power Management" in the Power Options menu. The default for the High Performance power plan is 0%, setting it higher will allow the processor to down clock to the base clock frequency when idle.
Code:
;Processor Energy Performance Preference Policy
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\36687f9e-e3a5-4dbf-b1dc-15eb381c6863]
"Attributes"=dword:00000002
I think that's how windows behaves. There is very little savings between balanced and performance.
