Ah yep, £200 then
I don't know then, this decision is probably up to you
I'm sure you could recoup about £45-60 selling your motherboard on so it'd be about an extra £150?
Yeah most likely something like that. Will have to ponder on that one I am leaning towards 970 SLI for G-Sync, Direct X 12 support and less power and heat but £150 is £150 that could be spent on other things. Will have to ponder that one looks like 970 SLI beats it as well in terms of FPS.
