Load up 2 copies of GPU-Z.
Make sure you change the focus on 1 so you are monitoring both cards.
In the sensors section set it so you are monitoring the MAX for each sensor.
Run a benchmark & check to see if the graphs are similar(should be almost identical).
Then run the games you are trying to improve performance.
Check the graphs again if they are similar.If they are not then it is something to do with the game setup or implementation of SLI
To reset the values in GPU-Z i just put the PC in sleep mode for a few seconds.
