970 SLI problem
13 Jan 2012
United Kingdom
Hey guys,
I'm having some problems when i play advanced warfare and inquisition, the background starts flickering really badly and on advanced warfare i can see the previous frames in the background as well
I dont think its faulty cards since in other games they perform well and i had the same problems with my friends msi cards when i tried them
What could this problem be? i have already tried switching around the sli bridge which didn't solve the problem
Does it support SLI properly? Flickering is common especially with shadows or AO if you force AFR and the game isn't compatible. You could try a different AFR mode in the nVidia control panel.
Max temp on top card goes to 71 degrees, I dunno about the afr thing I can try it when I go home.
Advanced warfare has an sli profile according to NVidia driver information if it works that is another thing
Well I suppose I could disable sli for advanced warfare, but its a bit annoying when my desktop goes all over the place
The ghosting you refer to I believe is caused by post processing AA, so turn any of that off. I had the same issue when I had SMAA enabled in other games.
