I upgraded from this trash:
to an evga 9800GTX+ 1gb
It finally arrived yesterday, after a trip to the post office - with a few bits missing, as usual with me
I had to run to the Stratford computer fair to buy a DVI cable because it wasn't in the box, also there is only one 6PIN power cable - on the box it said there should be two (I was confused with this because the card only has one PCI-E Power slot anyhow). OC nevertheless sent me a DVI adapter which will arrive on Monday for free
Box recommends a 500W PSU and I'm 75W short of that. I thought if I disconnect a CD drive and one HDD it will be ok.
the GTX+ has only one 6 pin PCI power slot so plugging in the PCI-E power cable from my cheap PSU was not enough, I had to use two different cables and plug 'em into the converter thing and then into the card.
It managed to start after some persuasion and a clean format (frikking hard upgrading from ATI to NVIDIA) I had the opportunity to test it briefly in some games. Remember that I usually play below 1k resolutions with graphics on low
I was gobsmacked when Quake Wars and COD4 put all settings onto max automatically and I was getting a consistent frame rate of 30 in QW (its locked to 30) and 80+-10 in COD. Wow.
Then it shut my pc down and refused to start again.
So Ive ordered a new PSU hoping that it will solve my problems.
I'm posting using my old ATI x1300
Now a few questions. When booting, the fan revs up and down. is this normal? Also, when the windows xp loading screen comes up, the fan revs and my system reboots.
I tried all sorts of reconnections to try and give it enough juice (im assuming its what it needs) to no avail.
Hopefully, once my 650W corsair arrives I will be a happy shopper.
I was gobsmacked when Quake Wars and COD4 put all settings onto max automatically and I was getting a consistent frame rate of 30 in QW (its locked to 30) and 80+-10 in COD. Wow. Then it shut my pc down and refused to start again.
