Not sure if anyone has posted this yet
http://www.fudzilla.com/index.php?option=com_content&task=view&id=5874&Itemid=1
- $599 which is about £360 by the time you add UK VAT. Probably £380+ by the time you factor in import duty.
- 600mhz core and 2000mhz memory, 256bit bus. So 50mhz slower then a stock GTS on the core, and memory 60mhz faster. So a downclocked GTS as people said. Still, if the reports are true about being able to run 2 of these for quad sli I'm guessing it should be the faster then 2xX2's in Crossfire X.
