- 27 Jul 2005
- The Orion Spur
Grrrrrrrr, this is a real bugbear of mine, so many expensive components out there held captive by a 50p fan on an otherwise fully working product!
I have a Palit Geforce 980 Ti Super Jetstream GPU and one of the fans is starting to fail, it's 5 months out of warranty and not sure what to do, there is noway I want to give it up for the sake of a fan, I've emailed jetstream support but haven't heard back from them yet
Any idea's what I can do?
This is my GPU - https://www.techpowerup.com/reviews/Palit/GeForce_GTX_980_Ti_Super_JetStream/4.html
I've looked for spares on ebay but no joy, a few gigabyte ones seem do crop up, not sure if I can bodge them on my card or not, have even considered water cooing but quite expensive and a lot of effort, don't really want to go down that road.
If you look at the heatsink in the link maybe I whack two 120mm fans on there some how?
