Hi all,
I've got a G1 980ti card and a Phanteks Enthoo Pro Mid Tower Enthusiast Case.
I feel like my card is running too hot and the cooling in my case isn't optiminal. This is my first gaming PC so I need a bit of help from you experts.
After reading a lot of forums about the G1 it seems that my card is running hotter than most, it reaches 80 degrees in most games but people are reporting 70 degrees.
Here are my afterburner settings:
Are these settings correct? I don't know if I should up the Core voltage or lower the Power Limit or change the fan profile (custom one?)
Also does fan placement within the case itself make a big difference to the temps?
Will provide pictures of my case if it's needed.
Thanks guys,
- Core Voltage - 0
- Power Limit - 130%
- Temp Limit - 85
- Core Clock - +120
- Memory Clock - +300
- Fan Speed - Auto
- Boosts to 1474Mhz stable in games
Thanks guys,
