Yep and I wish I could keep it but with only 1 Display Port, it doesn't fit my needs
Damn, if I'd read your OP completely i would have been able to tell you that and you could have cancelled the order.
Why didn't you just get a switch?
I've got 4 consoles hooked upto a HDMI switch, that takes up one port on the monitor.
It's this monitor https://displaysolutions.samsung.com/business-monitor/detail/1112/C24FG
I believe its a 48-144 freesync range.
This is why Gsync is superior to Freesync.
Full 30-144hz synchronisation.
No messing about with different monitors doing different ranges and or LFC needing to kick in.
It does what it says on the tin.
G-sync is only superior if the Freesync monitor does not support Freesync properly and considering how much monitors can cost we should all be researching any monitor before buying it anyway, regardless of whether it's a G-sync or Freesync model..
I have a gysnc monitor and have been really underwhelmed with it, I fail to see what all the hype is about it tbh.
Although it is somewhat a moot point as once framerates start dropping towards 40 and below its pretty meh anyhow but personally I find G-Sync's behaviour at lower framerates a lot better - FreeSync I can tell much more it is duplicating frames and the slower recovery/increased input latency from the way it is done.
