9950X3D power draw
28 Jan 2011
hey guys,
looking to upgrade my CPU to the 9950X3D. I currently have a Corsair SHIFT 750W with a 9070 GPU.
Surely this PSU will support a 9950X3D and a 9070???
thanks.
Do you mean a 9070 non-XT? If so, it should be fine.
If you mean a 9070 XT and you're using both, at maximum, at the same time (i.e. not gaming), I'd have preferred something higher wattage. That said, still likely to run without problems.
