- 9 Jan 2012
So earlier today I received a BSOD - Kernel Security Check Failure whilst playing some casual CIV.
I restarted and did some driver checks and everything came back completely fine however it then just froze without blue screening - even after 10 minutes of waiting.
So I hard rebooted and it wouldn't load up even the bios screen. Just blank then my monitor went to sleep due to no connection.
I took out everything other than mouse and keyboard, and changed from SLI to single card. I then tested with only one of my four ram sticks. ( I have 32GB in total )
All worked fine again, so went through testing each ram stick.
They all worked in each slot, apart from slot 4. No matter what stick I put in it didn't recognise it.
I've done 3 complete RAM tests and they've all passed with no errors. So I'm thinking strangely something has happened to make my 4th slot just go.
Other things I've tried are clearing CMOS and updating to newest bios.
Wiped all OC'ing.
Cleaned all ram slots.
Ran tests on all ram, CPU and GPU.
Any suggestions on what to do or test, or should I message OC to get in touch about RMA'ing my Motherboard?
Wiped all OC'ing.
