A 27" monitor for Photo editing etc ?
19 Oct 2002
Pembrokeshire
I'm looking for a 27" Monitor that will be used for many things but most importantly it needs to be good for Photo editing. At the moment I use a Dell 2408 WFP which has been a great monitor and I want something as good and hopefully better :)
What do you recommend ?
Is that based on experience of the monitor, having good reviews?
How does this compare to the Dell UltraSharp U2713H which is a bit more expensive ?
U2713H is the professional grade monitor with factory calibration and a high color gamut. So it will hit 99% of Adobe RGB colors.
The U2713HM is the more main stream monitor with a standard gamut color space and not factory calibrated.
Indepth analysis of both monitors from TFT central.
TFT Central U2713M
TFT Central U2713HM
It really depends how serious you want to get into photo editing, I mean both screens will look absolutely stunning it just depends if you need the color accuracy of the H version.
If you decide you do there is a rather large premium.
Own a U2413 which is the professional grade 24 inch version.
Thanks guys, I'm not to bothered about the price just wanted the best one I could get, I'll see if there are any other options but will probably order the H on the weekend.
"best" really does depend on whether you want and need wide gamut support i would say. your current screen is wide gamut so i'm assuming you do want that in the new monitor. The U2713H would be a logical choice. Other options with wide gamut are the Asus PA279Q and NEC PA272W. The NEC is probably a more high end model with some further useful advanced features (like a decent uniformity correction). Again, depends how much you want to spend and if you need those things
Ive got the Iiyama Prolite XB2779QS, i use it for photo editing and 3ds max with a bit of gaming on the side, excellent colours and contrast.
some people reported some light leak but i've not had any problems. far superior to my dell i had before
