A bit of basic overclocking advice needed please
28 Oct 2002
hi
i have just installed a new dual core amd 3800+ cpu and am trying to overclock - i have a copy of the guide from the forums but am getting a bit confused with some of the terminology and am unsure what to do next
so far all i have done is up the cpu freq from 200 to 210
what i am confused about is
a) the RAM divider - as i am not sure a) what it is at the moment, and b) what it is called in the BIOS (i have an ASUS A8N-E with the 1013 bios) - i think its 12(??) but even if it is do i start to increase or decrease it?
b) the memory setings in BIOS is 333 but i think i can change it to 400 with the typr of memory i have??? However if i do this i then think all i need to change:
CAS 2 to 3
tRAS 5 to 6
is this correct?
c) i haven't changed any voltages - again its a bit confusing because the BIOS just says auto so not sure what the setting currently is - HOWEVER i have now loaded PCPROBE which give me the following readouts:
vcore 1.34
3.3 3.26
5.0 4.87
12 12.1
cpu 31 degrees idle goes to 44 degrees under load
mb 32 degrees idle
do i need to change any of these?
d) am i missing anything else at all??
CPU-Z 1.41 report file
Processor(s)
Number of processors 1
Number of cores 2 per processor
Number of threads 2 (max 2) per processor
Name AMD Athlon 64 X2 3800+
Code Name Toledo
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Package Socket 939
Family/Model/Stepping F.3.2
Extended Family/Model F.23
Brand ID 5
Core Stepping JH-E6
Technology 90 nm
Core Speed 2100.5 MHz
Multiplier x Bus speed 10.0 x 210.1 MHz
HT Link speed 1050.3 MHz
Stock frequency 2000 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache (per processor) 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache (per processor) 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache (per processor) 2 x 512 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge NVIDIA nForce4 rev. A3
Southbridge NVIDIA nForce4 MCP rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 2048 MBytes
Memory Frequency 175.0 MHz (CPU/12)
CAS# Latency (tCL) 2.0 clocks
RAS# to CAS# (tRCD) 3 clocks
RAS# Precharge (tRP) 3 clocks
Cycle Time (tRAS) 5 clocks
Bank Cycle Time (tRC) 10 clocks
DRAM Idle Timer 16 clocks
Command Rate (CR) 2T
System
System Manufacturer System manufacturer
System Name System Product Name
System S/N System Serial Number
Mainboard Vendor ASUSTeK Computer INC.
Mainboard Model A8N-E
BIOS Vendor Phoenix Technologies, LTD
BIOS Version ASUS A8N-E ACPI BIOS Revision 1013
BIOS Date 04/07/2006
Memory SPD
Module 1 DDR, PC3200 (200 MHz), 512 MBytes, GEIL
Module 2 DDR, PC3200 (200 MHz), 512 MBytes, GEIL
Module 3 DDR, PC3200 (200 MHz), 512 MBytes, GEIL
Module 4 DDR, PC3200 (200 MHz), 512 MBytes, GEIL
thanks for the help
Diss
