Hello all...
Getting a little tired of all the humming and noise coming from my Thermaltake Tsunami case, so I started to examin what made all the noise, and to my surprise the front and rear 120mm case fans were to blame. When I bought it, the add said with "silent" front and rear fans, so I never thought they were to blame...
But I can see that they are both 22db each, I have found some rather expensive 11db 120mm fans - would that make a LOT of difference in terms of noise?
The fan on my Asus 6800gt also makes some noise, allthough not so irritating as the casefans, how are normal/stock fans on those Nvidia boards rated in terms of db? - what is the best fan solution for such cards?
Thanks in advance
Thanks in advance
