A few years ago I bought a 320d for 5k, kept it 2 years and put 30k on the clock only having to fork out for break pads and new tyres aswell as the regular services, so Im sure its possible to get a good reliable one for 8k if its what you really want.
I would try and get one with no more than 70k on the clock if you can, with full BMW Service history as a must and some kind of warranty just for peace of mind.
Chain driven
You'll not find the Civic any slower than a 320d
Just seen that VAG did a recall on the injectors on the 2.0 TDI's.
What are the common problems with the E90 320d's??
The BMW and Audi are at the top of my list at the moment.
Pre-lci swirl flaps, turbo failure, egr and coolant thermostats, fuel breather pipe leaking
Lci timing chain, dpf over 100k, turbo failure, thermostats
You'll find most Cars have thier common faults. I can tell you one thing, try driving quickly round some country roads in an e90 and then try it in some of the less prestigious Cars.![]()
Yeah I just don't want catastrophic reliability problems.
[TW]Fox;22845502 said:Then don't buy a diesel E90 M Sport with a budget of justr £7k. This is the very bottom of the market for those.
Whats the point in picking a small diesel engine to save money on fuel only ending up having to spend it all on £300 a pair rear tyres and repair bills? Seems totally pointless.
[TW]Fox;22846461 said:I didn't say it was slow, I said its an engine you pick to save money. So if you want to save money why buy an older BMW? Better off with something newer and cheaper to run.
