The dilution difference between 1 per 50 units and 1 per 51 units isn't going to be significant.Looks like i've been doing my 2 stroke mix wrong in my chainsaw and strimmer. It's 50:1. I generally add 100ml of oil to 5l of petrol.
Quite late to the discussion here it would seem this is the correct answer. They key is the terminology of mix vs diluteI think some people are comparing "mix" with "dilute"? Mix 1:10 generally means 1 part of A plus 10 parts of B. "Dilute" generally means (and always to a scientist) make 1 part of A up to ten times the original volume with B (1+9 effectively). That said, a lot of instruction manuals are written by people with no scientific background, and who think the two terms have the same meaninhg
Yep. This is ridiculous. Only encountered it once coming to the UK. I would imagine everywhere else in the world, it is twice a month. Same confusion ensued with bi-weekly but in that case, I understand it as every two weeks. At least bi-annual and biennial are different spelling to differentiate.This thread reminds me of this ridiculous term
Completely clear!
I will defer as that also makes senseNo, as DP pointed out the keywords are ratio or fraction.
Also the notation for ratio ":" is being abused a bit which has added to the confusion.
Dilution ratio 1:10 means 1 part to 10 (like any other ratio)
Dilution fraction 1/10 means 1 part out of 10 (like any other fraction)
