I'm after a hd utility i can use before i load windows to format and create partitions.
i used to use acronis OS selector that had a hd utility but this doesn't work now it always has but now i have a sata2 hdd and it doesn't seem to work maybe a dodgey floppy but i cant find the cd thaqt had it on to try another.
win xp btw.
conroe, p5n-e sli, samsung spinpoint 500gig sataII
win xp btw.
If you can get it working though then i would use that over anything else.
