A Disk Error Occured! press ctrl + alt + del to restart
i'd check all the connections to my hard drives, then run a scan on the drive to make sure it's not faulty, or your windows could just be corrupted
all cables are fine, windows is fresh. I've just built this computer.
I guess i need to change the master boot record, which i dont know how.
Next thing I would do is schedule a check disk. Right click the hard disk drive icon, click on Properties, Tools and select 'Check now'. It will schedule a check disk for when you next restart your machine so do just that.
That's very strange :confused: Is the HDD being seen by the BIOS ok and have you set the boot order correctly so the HDD is the first device your system try's to boot from?
stick the drive in another computer and do a chkdsk on it?
done, still not working
yes its the first priority.
Does anyone know how to access MBR, cos i remember i solved this issue a while ago using mbr, but i dont remember how
There's an easier option you could try - boot from your Windows 7 disk again but select 'repair your computer' this time. When you select this you will be given a menu and one of the options is 'Fix problems that prevent windows from starting up'. Try this.
done that, not working
By the way... if you want to try and repair the MBR.... http://support.microsoft.com/kb/927392
i did that, but thats not what i'm looking for.
My one has like a menu where you can chose, i serioulsy forgot what it looks like :(
