- 27 Mar 2004
- Between Realities
1. If I have a fire resistance of 75 (Dark elf trait I believe) and I have a ring with resist Magicka 10, Does that give me a resistance of 85 to Fire?
2. If I add poison to a Bow, Does it automatically poison the arrows fired from it? Otherwise it would be pointless
3. I currently have the Ebony Longsword, Is there a better weapon out there, Longsword wise(As I like to use my shield) It does 7 Damage, So i'm guessing there will be, And what would you recommend attaching to the sword, Magic wise, Once I get into the University.
I'm only level 7 by the way.
] will see you right through most of the game for all manner of reasons. Remember that your ebony longsword is only doing 7 damage because of your relatively low level/Blade skill/Strength - increase all these and the same weapon will naturally do more damage.
