Hey, nice builds can you give us some info on the Torrent please, are any of the supplied fans PST? reason I ask I'm confused how having 2x180 PWM and 3x 140 3 pins all on the same hub works?
Do the 180s get a signal and the 140s just run full tilt at 12v?, I was thinking i'll run the 3x3 pin 140s off the hub and use voltage control in bios for 7v then have a splitter on the 180s if they not PST but still leaves me with rear fan 140 PWM i want to add with no headers left (only 2 on auros elite and not wanting to share CPU header as I like case fans linked to VRM Mos temp, i'll check if cpu_opt can be used exactly like system headers changing temp source)
Wafflling.... in short how does mixing 3 pin and 4 pin on the nexus 2+ hub work, surely people are not running all their 3pin fans at 12v max rpm?
Cheers
