Hi all, as im slowly gearing towards my new build I have a few questions that hopefully you all know the answer to
I've seen a lot of people recommend the noise blocker PWM fans as the fans to go for, for the radiator due to how quiet they are. Is it a good idea to use them for every fan in my case (PWM version) so that I can regulate the speed of all of them?
That leads me onto the next question which is I am looking into getting a Phantek case which has the PWM hub on it, if I connect all my fans to the hub and the speed is regulated by the motherboard itself does that mean the fans should always stay pretty much silent? or is there more to be done than just simply that to maintain whisper quietness?
with all the fans PWM controlled on the cpu fan header, could I use a program to control the fan speeds? or is it all automated and that's that?
