- 27 Mar 2013
-40 degrees C is quite a cold winter. What's the UK record, -20? I use premix stuff (good to -10, although I've not tested it) so I can't see how it would freeze on after being sprayed. I used to mix it myself, but I don't know how well it gets mixed in the tank, so maybe that's the issue?What concentrate are you using though. In the Uk most people use water, or at least water with some antifreeze in. That’s why I said the wrong tools. Of course neat water will freeze.
Here you use -40C concentrate with no water and it still freezes.
