Has anyone done an A-Level from home, and do you recommend a learn-at-home provider like ICS, or is it better value just to pay for exam entrance somewhere and buy the material yourself?
Aha. Well then why not just ask at local exam centres (colleges/sixth forms) if you can sit the exam. They should give you the specification and it'll be cheap as chips (<£30 per module).
Screw material if you can already do it. Just get a revision guide or two.
