Nitefly said:No its perfectly true. You did no work, came out with top grades on luck because they asked 'the right questions'. If you work you bum off to the max, there shouldn't be any luck in it at all because you know eveything anyway, surely?![]()
*Groan*Zefan said:But he didn't work his bum off, and he was LUCKY, hence there is luck, you even said it![]()
I think we can let this die nownitefly said:If you work you bum off to the max, there shouldn't be any luck in it at all because you know eveything anyway, surely?
Expanded and explained version - If you know eveything, there is no luck involved because you know the correct answers to every sort of question. Therefore you can not have 'bad luck' as you will not get a question you can not answer!
EXACTLYLocrian said:No, you just go through all the past papers, learn the layout of the questions, and hope that the format isnt changed till next years lot![]()
Damn, now that would be good. I'm not too bothered about results, I just want to get into my firm choiceCiba said:Some of you might find you get your Uni confirmation letter before heading into school to get your results.
I take it you're not drinking theneXSBass said:Tomarrow will be a day long remembered![]()
.Phnom_Penh said:I take it you're not drinking then.
Arsey said:AS level for me tomorrow aswell![]()
are you all posting your results?
Only if they're worth postingArsey said:are you all posting your results?
Please don't turn this into the student room 2Arsey said:are you all posting your results?
