A little help :)
sgx.saint said:
So that motherboard is decent board?
Is it SATAII compatible?
Is the Case all metal/aluminium? Is the case a good case?
Will I need any additional fans/cooling solutions?
Thanks :D
Yes, the DS3P is really the board of the moment and you can't get much better.
Yes its SATA2 compatible ( as it says on the description "- Features SATA 3Gb/s" )
The case is mostly aluminium. Read the reviews for more info.
If you are going to be overclocking ( which I STRONGLY advice for that CPU ) I would get a better cooler. May i suggest the Noctua http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-NC
