I downloaded a torrent last night that was supposed to be an xvid of a tv show i used to watch and after extracting the resulting file was a single .rar file an not an avi as i had expected which immediately set my spidey senses tingling.
I tried to scan it with MS Security Essentials but for some reason it wouldn't complete the scan. I scanned it with malware bytes which i reported it as clean so i decided to open the archive (not extract) to see what was inside. The file inside deadwood.avi.exe so instantly knew it was a poor attempt at hiding a virus so i deleted everything.
About 20 seconds later Security Essentials popped up warning me about three risks, all trojans, from the file i just deleted. I clicked 'clean computer' and it reported it as a success.
I'm basically very paranoid when it comes to security which is why i wanted to ask on here if I can safely assume that everything is now OK or if i should perform further checks/tests or just go ahead to reformat to be on the safe side. I would tell you what those trojans were called but for some reason Security Essentials hasn't logged the history.
Thanks.
Thanks.
Your AV's are just warning you of what was in the archive/caches, without execution of that file your safe.
