I'm looking to upgrade my PC to play current games, preferably really well.
I haven't touched the PC for around 5 years (it's covered in dust inside and out, but seems to be working well.
I have absolutely NO idea how to build a PC, so I was initially looking at buying prebuilt for around the £800 mark, but I'm wondering if it'd be more sensible and cost efficient to just upgrade the one I already have.
I ran Piriform Speccy and got the following results for specs:
Operating System
Windows Vista Home Premium 32-bit
CPU
Intel Core 2 Duo E6600 @ 2.40GHz 23 °C
Conroe 65nm Technology
RAM
2.00GB Dual-Channel DDR2 @ 400MHz (5-5-5-15)
Motherboard
ASUSTeK Computer INC. P5N32-E SLI (Socket 775) 40 °C
Graphics
Philips 230C (1920x1080@60Hz)
640MB NVIDIA GeForce 8800 GTS (BFG Tech)
Storage
465GB Western Digital WDC WD50 00AAKS-22TMA SCSI Disk Device (RAID)
Optical Drives
TSSTcorp CD/DVDW SH-S183L SCSI CdRom Device
Audio
High Definition Audio Device
I'm sooo out of touch with PC hardware, but even I can tell that pretty mucg everything needs to be replaced. But, the HDD still seems to be ok (although I'd be tempted to add a SDD...although I'd have no clue how to install it or set it up)
I THINK the case itself is pretty good. Very big, a lot of ventilation, and there are two large fans (with pretty blue lights) at the front, and one at the back (the case is 'Antec').
The tiny bit of writing I can see on the PSU says 850W, which I'm guessing would be ok.
There's also a large fan attatched to the motherboard, called a 'Freezer Pro 7') ...but I have absolutely no idea whether that's part of the motherboard, an additional fan or what.
As I said, I have absolutely no idea when it comes to the insides of a PC!
So, what should/could I do? Do I bite the bullet and buy new, or can even an idiot like myself mane to upgrade the PC?
Can go up to around £800 but around the £600 mark would be even better if it wouldn't mean taking too much of a hit to quality, so what ready-made, or components would you go for?
Lastly, Windows 7, or 8? Would it be easy enough to install it onto a new SSD?
Thank you!
Operating System
CPU
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
Thank you!
