A message to Stulid!
Just up multiply, leave vote on 1.3 (whats their max?) and work myself down. This will be a far cry from auto overclock lol.. You've cost me so much monies :P
The Vcore may alter automatically if the SerialVID works perfectly, basically the board automatically adjusts the Vcore to suit.
You just set the multiplier from 33X to say 40X, then re-enter the BIOS, then have a look at the Vcore, if its increased on its own while still on AUTO setting then your good to go.
It should change to this,
Stock-4GHz on Stock VID
4.0-4.3GHz 1.300v-1.325v
4.3-4.5GHz 1.325v-1.375v
4.5-4.8GHz 1.375v-1.450v
I'm guessing cherry picked chips hit 4.8. Also whats the max vcore for intel? I've never been to the darkside lol. Always been with AMD (You should know by now how many issues I've had)
Can you guess the case?
