Is it possible for someone who should be consuming around 4300 calories a day (according to Gordys thread) to actually lose weight when they have only been eating 1500 or so for at least the last 7 months?
Or is it a case of your body being so used to not getting enough food for about 5 years that it is hanging onto every last bit of fat it can?
,you should be able to roughly work out how many calories you are burning doing those sports ,i.e if biking burns 350cal per hr you need that just to do the excercise ,thats without calories needed for recovery ,badmington 270 to 450 cal ,so if you bike twice a week and badmington twice aweek thats roughly 1500 cal needed just to do the excercise in the first place without the standard calories needed just for a normal day,if not enough calories are taken in then you will lose weight as your body uses muscle for fuel when it runs out of fat, ive not read gordys sticky but it should contain all the info you need.
