A Quick DLSS Question
Ive never seen any posts from AMD owners, slating their DLSS, which is done via software.
Because there isn't any reason complain? It works perfectly providing superior image quality at 4K from higher base resolution like 1800p, than any NVidia card using DLSS except the 2080Ti which are in par.
And is game agnostic, assuming is DX12 game, while DLSS is applied on handful of games only.
Not in comparison screenshots it didnt. Worse FPS as well.
First hand DLSS looks better than running the screen at a lower res.
Id rather the screen run at native and the game render at a lower res than all running lower, it just doesn't look good at all, it's screen dependent.
Is GPU dependent. 2080Ti shows better image quality than 2070 for example with DLSS on on same final resolution with same ingame settings.
Because Nvidia for each card is using lower base resolution. 1440p for the 2080Ti and something bellow 1080p for the 2070
No both 2070S and 2080Ti can display 1440p, the game lets you choose. The only difference is fps between each card.
Absolutely no image quality difference between the cards.
Or you could turn the res down and use sharpening. I'm sure I saw a vid posted here of good results using both NV and AMD's sharpening features :p
HuB video, worth a watch IMO. As with all things subjective, YMMV and pick what you like most - so long as you're happy, don't worry about it IMO.
Watch from about 8 minutes.
