- 5 Jul 2005
I've got an old cheap Zorro case that I'm using for my first build. It isn't really ideal but it will do. I've bought 3 Akasa Amber series 80mm fans. Two go in the front of my case brining air in and another is on the back of the case taking air out. I've got an old rubbish fan in the middle of the side casing.
The Amber series 80mm fans are rated at about 25.4 CFM. I've been thinking about putting a more powerful 80mm fan on the back of the case and putting the Amber 80mm on the side panel. I've seen one rated at 32 CFM. Would this aid better air flow in the case if a more powerful fan was sucking air out than the Ambers?
Also I've seen a cheap 4" case lighting kit for £2 that includes two tubes. How much heat to these kick out as one reviewer said that they get quite hot?
