A quick go with a Q6700 GO stepping...(inconcusive) not 56k friendly ..
29 Dec 2003
UK
A quick go with a Q6700 GO stepping...(inconclusive) not 56k friendly ..
I briefly had my hands on a Q6700 GO stepping last night (by mistake, but thats another story) :p .
I thought it would bit rude not to give it a very quick test, though it didnt go so well tbh.
My pc wouldn't turn on initially with it, all I got was mobo capacitor squeels and then the pc turned off. I threw my E2160 back in and updated my vanilla P5K to the latest 0603 bios and then it booted fine. Even though it is a Q6700 (10x266) it ran on my pc at 9x266 by default thouht it let me raise it to 10x in the bios :confused:
Here I fired it up at 3.2Ghz and ran a little prime to see the temps.
It was going a few minutes before I remembered I had a quad core and dual prime wasnt going to push it lol
Shot at 2007-07-12
The highest it would load to windows with stock volts was 3.5Ghz, it failed to a 3.6Ghz.
I raised the vcore to 1.45v and it loaded windows fine so I thought I would try some quad prime, this is where I found a weird bug which I didnt have time to figure out how to fix.
All ready to go with the priming @ 3.6Ghz
Shot at 2007-07-12
Here it is priming, but notice the clock speed, its gone back to stock clocks , its like a reversed speedstep :confused:
Shot at 2007-07-12
I tried many different speeds and it always did this. With any kind of load the speed fluctuated between stock and the set speed.
I ran a few benchmarks and it underperformed for the clockspeed.
Nuclearus
Shot at 2007-07-12
IT should really be at the top of the leaderboard in this thread.
I ran a 3D mark 06 too with my 8800 GTX running 620/2000 and got 13267 marks Which again is kinda low compared to similar spec in THIS thread.
You will probably want to know that the highest I could boot at was 4Ghz but this wasnt even stable enough to take a screen shot, the highest I have proof of is 3.96Ghz. I don't think curing any of my problems would make this any better, i think its just the limit of the chip...
So pretty inconclusive, i hoped to have a better night with it but the speed problems spoiled that, Its most probably a bios issue though rather than the chip though.
I don't have the chip anymore to do anymore testing.
Gonzo0 said:
Was this ran under stock cooling or your water cooling?
This was under water cooling. I really wanted to see the temps compared to the B3 stepping but because it seemed to be changing clock speed I doubt mine are correct.
soo 3.9Ghz stable eh? not bad. I was expecting it t break the 4Ghz mark stable but 3.9 is plenty fast :p
Definately an improvement over the current revision :)
3.9Ghz was not fully stable, it was good enough to run super_pi etc but rebooted with 3D mark 06 :p
It seemed relatively stable at 3.78Ghz but i couldnt test with orthos, plus the volts were quite high ;)
I didnt seem to need much vcore to get to 3.6Ghz but over that and it needed far too much.
Jokester said:
Hmm that's disappointing then.
Jokester
Definately not what some people were suggesting they could do, then again mine could be a dud, but most ES chips are usually amongst the best clockers.
Some of guys over at XS were saying that they're ES chips weren't any faster than the retail ones they had hold of, it could just be down to a flaky BIOS I suppose.
Jokester
Could this G0 revision just be a marketing ploy by intel to try and boost sales (not that they need it). People are going to think "ooo a new revision i bet its better than the old one" then it turns out to be performing the same as the current revision.
Im sure it will bring temps down a bit but I think people are expecting them to also clock much higher but Im not sure thats the case. The dual core 6*50 chips seem to have benefited more from the new stepping.
Are they:
http://forums.overclockers.co.uk/showthread.php?t=17753617
If you ask me them temps in that thread are pretty high to be honest, especially for water cooling.
Could just a non flat IHS again I suppose. It should be reasonable to expect 4GHz prime stable on the E6850 under water looking at some of the results posted.
Jokester
