A Quicky Please
21 Mar 2004
Dorset
My current hd ( 160gb SATA)is still working but I suspect there is something wrong with it.
I have brought another hard drive (160gb SATA2) which I am going to fit and do a fresh install of XP.
My question is can I leave the current HD in situ with the OS etc on it, fit the new HD install XP on it and then access the old drive using Windows Explorer to copy my settings and data files onto the new HD? I will then refomat the original HD and use it as a back up (or possibly set up a Raid 1 Array). My worry is that when I try to access the original hard drive my pc will try and open Windows XP again!!!!!
marc2003 said:
when installing xp on the new hdd, i'd unplug the old one temporarily. could save a lot of hassle in the long run. :)
Thats what I was thinking, At least he won't have to edit the boot.ini after deleting the old OS and it also means he won't delete his stuff on the original hard drive by accident.
Just thought I'd check for any more advice before switching on and bingo! I'll disconnect the original drive while I get XP installed on the new one.
