- 24 Mar 2023
- UK, Hampshire
So I decided to build a cool and quiet rig for gaming and UE5 + Some Modelling + Whatnot
Requirements:
Nice to have:
I searched if there were any reasonably-sized PC cases which could fit a 560 rad. No results. So I decided (not a matter for discussion) to build a custom PC case of aluminium extrusions and some bespoke machined parts (perforated side panels, machined mounts, machined and bend sheet metal parts).
ATM I am searching for companies that could offer some of the aforementioned services (bending, machining, waterjet cutting) for a (relatively) affordable price (e.g. I asked for a quote for radiator mounts and been quoted like 2k). The parts I used are not that important. I could provide details if there would be an interest, but for know all you need to know is it is a 4080 FE + 7950X direct die. Side panels are meant to be waterjet-perforated 1.5mm copper sheets (no special reason, no I don't think that it would affect cooling performance).
Case WIP (Design)
Pump mounting slider
Radiator mount
Mounted radiator
PSU mount
Shroud with a cutout for an external audio interface
Am IO tray that keeps cables inside the case and matches IO cutouts on the front
Bare frames and panels
I apologize for external links, but I couldn't upload any images.
I would appreciate any insight, or offers (PM).
ATM I am looking for a CAD model of any ATX motherboard (the model should not be be a converted polygonal model), and for a way to attach internal header cables to the tray (I have no idea how I am going to do that). This would be it for now. I hope you found this log interesting, or even better, you have an advice or comments.
Requirements:
- quiet
- proper airflow
- water cooled
- easy to maintain
- 560mm radiator
- as tidy as possible
- as cool as possible
- as compact as possible
- a decent audio interface
- speedy front IO
- decent looks
- monitoring panel
- resistant to leaks
- upgradable (with other water cooled components)
Nice to have:
- cheap (I don't have much hope here)
Case WIP (Design)
Radiator mount
Mounted radiator
PSU mount
They do laser cutting and folding and I think machining too. The machining will be stupid money though.
