Hi there
1920x1200 monitors are a rarity now.
Thankfully Asus know this and arriving soon we have this lovely monitor:-
Asus VS24AHL 24.1" Widescreen Professional/Gaming LED Monitor - Black @ £239.99 inc VAT
Delicate touches make a monitor truly great, VS24AHL 1920x1200 IPS LED monitor, with16:10 aspect ratio, 80,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. The VS24AHL reaches a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. It’s easy for you to reach a desired viewing angle with support of pivot, tilt, height adjustment and swivel functions.
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. VS24AHL adopts 178°(H) / 178°(V) ultra wide viewing angle IPS panel that eliminates color shift on your screen no matter where and how you look at it.
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
Specification:-
- Panel Size: Wide Screen 24.1"(61.13cm) 16:10
- True Resolution: 1920x1200
- Pixel Pitch: 0.270mm
- Brightness(Max): 300 cd/m
- ASUS Smart Contrast Ratio (ASCR): 80000000:1
- Viewing Angle (CR?10): 178°(H)/178°(V)
- Response Time: 5ms (Gray to Gray)
- Display Colors: 16.7M
- Signal Input: HDMI , D-Sub, DVI-D
- AV Audio Input: HDMI
- Earphone jack: 3.5mm Mini-Jack (for HDMI Only)
- Chassis Colors: Black
- Tilt: +20°~-5°
- Swivel: Yes
- Pivot: Yes
- Height Adjustment: Yes
- VESA Wall Mounting: 100x100mm
- Slim Design: Yes
- Phys. Dimension with Stand(WxHxD): 561.6 x 534.5 x 224.8mm
- Box Dimension (WxHxD): 637x 437 x174 mm
- Weight: 6.1kg
- Warranty: 3yr
Only £239.99 inc VAT.
ORDER NOW
A proper resolution with a decent yet responsive IPS panel.
Specification:-
- Tilt: +20°~-5°
- Swivel: Yes
- Pivot: Yes
- Slim Design: Yes
- Weight: 6.1kg
- Warranty: 3yr
ORDER NOW
