More of a sidegrade than an upgrade, you'd be getting similar performance if not a bit better with the 295. Only real benefit is dx11 which at this moment in time is being slapped into games any way game devs can get it in just so the box can say "dx11 supported".
Woa, no dual GPU issues is a big plus, also power is better on the 5870
Ye, my OC 5870 will blow any 295 away.
hmmm
you could probably sell the 295 for the fat end of the cost of a new 5870, at worst you may have to put a few quid to it. If you play a variety of games you may not notice the difference overall - somegames the 295 beats the 70 by a few fps, some it loses a few.
For very little or no outlay you'd get a brand new card that runs cooler, quieter and uses less juice than your 295 by a long way. It has dx11, the ability to run 3 monitors for some eyefinity goodness and also a new full warranty. The decider for me would be that your 295 is probably at it's peak used price now - in a years time I'd wager the 5870 will have retained a higher resale value than the 295 by a fair margin. Add to this the ability to add another 5870 in the future which is better utilised (2 way crossfire against 4 way sli).
Doubtful, at stock speeds the 295 is somewhat faster. Not as if it can't be overclocked.
Nah, I well beat oveclocked 295's in many benchmarks/games, I'm a good 10FPs quicker in the crysis bench, 295 may surpass in the odd game "TWIMTBP games mainly " but not by much. That's why if you own a 295 you should sell up while they are still worth something, get a card that's future proof and uses a hell of a lot less watts yet performs better.
Well this review says different
http://www.techpowerup.com/reviews/ATI/Radeon_HD_5870/10.html
Not many have the 295 in the same review as the 5870, only one i seen upto now.
That review means little these days as its 5 months old on release drivers. Things are definately much closer these days.
Not many have the 295 in the same review as the 5870, only one i seen upto now. Crysis is close but games like farcry 2 the 295 is ahead by a good 10fps or so.
Obviously doesn't mean anything either since it was back in September when the 5870 had immature drivers.
Already been said above... Its the only review i could find that benched the 295 as part of the 5870 review.
So why even bother posting it?
