Bubba said:Yes you will still need to plug in power.
Well, WD wouldn't have gone through all the trouble of making a separate cable if the existing SATA cable was so perfect, would they? If you move computers around a lot, or if a secure connection is critical, you don't want to take chances with the normal cables.Jeff Crawly said:tbh buying that cable is a waste of money!! The SATA leads that come with your mobo perform exactly the same and provided you route the cable sensibly they are more than adequately secure!
