Hi everybody,
I require some assistance from people who know what they are talking about!
Basically I will be buying a 32" tv for my bedroom, and I have a lot of videos, looking at about 1TB of video files and I would like to use a standard HDMI connection to connect the two. The tv will be 1080p so its just easier resolution wise.
I might play some games occasionally but very rarely so something capable but cheap would be good.
I also listen to a lot of music. So I will be ripping my cd collection into FLAC and eventually buying a DAC to join my amp that I already have so a sound card isn't needed but a decent amount of HDD space is.
This is a spec that I came up with, I'm not sure if its any good, so change away!
I would like to spend under £750 in total, inc delivery and including Windows. I thought 7 would be the best one to go for even though I have never used it.
For basic usage I doubt I will find it THAT much of a difference between Vista and 7.
Anyway, my spec
Is there anything that you would change?
Also is it possible to make it run quite cool and quiet?
Thanks very muchly
Deep!
Anyway, my spec
Thanks very muchly
Deep!
