A stroke of luck
If you rub it vigorously for a few minutes, it will spurt a load of luck all over your face. Some say taking it in your mouth and swallowing the luck will ensure it keeps on giving for years to come.
Dangling your genitalia in a bath of electrolyte and passing a mild electric current though it may sound like fun to you, but it's unlikely to remove any rust from anything.
It isn't lucky. Hang it how ever the **** you like because it won't make a difference to your life at all (unless you hang it badly and it drops on your head and kills you).
That's a fantastic idea, thank you!
I'm all for having a go at this, and it just so happens that I think I have everything needed.
However, I'm a bit worried about the effect that electrolysis may have on the luck contained within the horseshoe.
Will the luck mind being electrocuted?
Will the electrons hinder the flow of luck?
This horseshoe may be hundreds of years old, and might not appreciate this witchcraft that you're proposing.
I might sleep on it and make a decision in the morning.
PS I meant sleep in the idea, not the horseshoe. That's in the garden (pointing upwards).
