A sudden strange problem! (need your help)
If its already corrupt chances are youve lost it, you have to back up before it becomes corrupt. You could try buying a new HDD and installing your OS on it, then attach the old one as a slave and see if you can pull any info off
Right now I can enter the disk even in normal mode but for while. I have tried to create a backup with Acronis True Image but it failed. Now I am taking a System State backup...
Hi all,
I am waiting for a disk replacement and I also got some Kingston 1066 ddr2 (KHX8500D2K2/4G). I am trying to run in Asus P5K-E but no matter the bios settings I cant use them in dual channel mode. Problem is that no matter the speed (800 or 1066) memtest never completes in dual channel mode. Any ideas?
HI again,
after replacing my last velociraptor with the new one, the pc worked fine for a week. Yesterday the message "display driver stopped responding and has recovered" appeared again, monitor started to freeze go black and then apperaing again an dfinally pc crashed. Although the drive was new I have started a chkdsk /r command and guess what! The new velociraptor has bad sectors!!!!! Right now I am very reluctant to replace the disk for a new velociraptor. Could you suggest any other disk reliable and fast?
thank you in advance
