A way to run a higher than native res on an LCD for benching?
26 Mar 2003
Hertfordshire
I'm thinking i might get the Hazro 27-inch when it arrives at OCUK, but i want to know how some of my games will run at this res. Is there anyway i can trick my monitor to run the higher res for a benchmark run?
this used to work for CRTs if you used a driver that could give you the options of higher resolution. I didn't know it could be done with LCDs too. Cheers, I'll give it a go.
