A64 3000+ skt 754
5 Jun 2004
Hythe, Hants
over the last couple of days MSI Corecenter has been making a siren sound every now and then with absolutly no indication as to what is wrong, the only thing i can see that could be the problem is the Vcore being sat at 1.5v, is that the default voltage for the above cpu?
The comp crashed over the weekend and did start moaning at boot up so I dropped the FSB by 20mhz to bring it back down to stock speeds, Temps are ok , cpu idling at 36c and nb @ 46c, 3.3v @ 3.14, 5v @ 5, 12v @ 11.9,
Any Ideas?
just noticed that my 3.3v rail is a bit flaky, its now at 3.09v i havn't seen it drop below 3v, but was playing CSS for about 30mins and it started the siren noise's again.
This is an Antec Truepower PSU btw
What volts are you putting through your memory? If I remember right the 3.3V rail supplies the juice for the ram.
And what is your complete spec?
