- 5 Jul 2005
Is this a decent CPU for the money (£77.49). Also, will a heatsink and fan I'm using with a socket 754 A64 3000+ work with this CPU or won't it fit.
Regards.
Regards.
TaKeN said:It wont fit your current socket im afraid![]()
I'm in the same boat as you mate, mines a Winny 3200+ @2.2 though. The price is really tempting me but i just cant decide. In fact the main thing thats putting me off is that i'll have to update my mobo bios and that strikes fear into my heartt31os said:Be interesting to see if its a good increase.
Have my 3200 @ 2.5 and was considering a 4000 SD but decided it wasnt worth it.
Please post results up, curious to see the variance between the two. Though i'll need to know if you clocked yours or not.![]()
.t31os said:Be interesting to see if its a good increase.
anything over 200mhz or any later bios versions stops the computer from booting.
Cheers for that mateDanF said:K here's the results, all with an X800XT at stock. Gonna put the 1800 in next. The memory is always running 1t-2-2-2 timings. Board is an Asrock Dual-Sata2 with 1.5 bios. My mobo and memory have some issues with each otheranything over 200mhz or any later bios versions stops the computer from booting.
So about 50% faster in CPU bound situations over a winchester/venice at 2ghz and will make very little difference if your GPU bound![]()
, hmm i think i'll defo be held back by my GPU in games (6800GT @ Ultra speeds) unless i get the 7800 AGP card but theres no point really. I think id be best of just leaving it and getting a whole new Conroe rig when some decent games hit. Cheers.Nice one, id probably get one if i didnt have to update the mobo bios, i just know i'll bork my mobo if i do thatDanF said:Well it makes Oblivion a bit smoother, and in wow i can max out the draw distance with no slowdown, used to keep it at half way
Gonna put the X1800XT in now and see what it does to Oblivion
. I just tryed to overclock my winny to 2.4 to see what it would run like and it BSOD on me
, i got it to 2.35 and got lower benchies in everest that at 2.2 for some reason, think it might be because i had to put the mem on a divider. TaKeN said:Sorry i thought you meant you wanted to put the 4000 Chip into a SKt 754 Board..
DanF said:K here's the results, all with an X800XT at stock. Gonna put the 1800 in next. The memory is always running 1t-2-2-2 timings. Board is an Asrock Dual-Sata2 with 1.5 bios. My mobo and memory have some issues with each other anything over 200mhz or any later bios versions stops the computer from booting.
. So I was thinking of getting a S939 MOBO and get one of these babies while there on offer, and just chuck it into my old case and keep everything else. Possibly get a 1800XT in a few weeks as well if there still about
warren_1979 said:I was going to go conroe or X2, totally new everything, but when I sat down and did the sums I just couldn't afford it.
